P6 crank vs SD1 crank
JP.
Post by JP. »
Could it be that the rear snout of the P6 crank is longer as SD1 ??
Apparently mine is ???
Top one is SD1 ( 3.5)
Bottom one is P6 and its about 2cm longer ( about 0.8" )
If this is the case I am stuck to the P6 crank Ill guess by the Citroën transaxle..
'73 Ford F250, 6.7ltr V8
Building a GT40 mk2
harvey
Re: P6 crank vs SD1 crank
Post by harvey »
P6B lipseal cranks are directly interchangeable with SD1 cranks. The P6B ropeseal cranks are the same dimensions but the seal land is different. My guess is that the lower crank in your pic has had an insert made up to suit your individual application..
JP.
Post by JP. »
After very close inspection I found a weld. so indeed its made up for purpose of the transaxle.
Building a GT40 mk2
JP. wrote:
Sat Mar 31, 2018 2:51 pm
Stick it in a lathe and turn it down to original spec.
JP.
Post by JP. »
Bad idea, I need the extension as I am running the Citroen Transaxle. It holds the pilotbush.
fo now, I found a solid SD1 bare block, after a hone still in spec.
That will recieve myP6 crank and P6 10.5cr pistons
Building a GT40 mk2
JP. wrote:
Mon Apr 02, 2018 2:07 pm
Ah, sorry. I thought you needed the shorter one.
Can't you have the back of the crank turned out to the biggest size safely possible and have an extension press fitted with the crank heated up to allow maximum expansion and the bit being fitted blasted with a CO2 extinguisher?
