3.5 flywheel?
3.5 flywheel?
Post by 666 »
Hi, I am after a flywheel for a early 3.5 for a manual conversion. I'm in Australia so limited for options, I have a P76 bellhousing but been told the P76 flywheel is different. Manual P6 or SD1 are rare here. What about Range Rover? Cheers Peter.
garrycol
Re: 3.5 flywheel?
Post by garrycol »
Finding a 3.5 V8 manual flywheel in Aust should not be an issue - there are plenty of old landrovers around - TR Spares in Adelaide probably have some - try advertising on www.AULRO.com and I am sure you will get a response.
I also understand a manual 3.9 flywheel is the same as well.
Garry
