Hello
I have An 11D engine (dismantled with worn-out camshaft)
and a 17D engine (which i suspect has a worn camshaft) Both 9.35:1 compression from a Range Rover:
They should both be rated about 124-126 HP DIN there is no restrictor in the inlet manifold!
The cylinder heads have cast number ERC0216, same as SD1 Carb
I would like to know what the set up difference is compared to a 157 HP DIN 3.5 Rover v8 engine from a 1979 Rover SD1 engine: cam ? Carburettors ? Anyone ?
It seems that when they introduced the 9.35:1 comp engine they fitted a low lift camshaft:
- High compression engine 9.35:1, 125bhp @ 4000rpm, 185lb/ft @ 2500rpm,
requires 97 octane fuel
- Low lift camshaft,
- 3.5 ltr V8 Compression: 8.13:1 :
3528 cc V8, Max power: 130.2 bhp (97.1 kW) at 5000 rpm. Max torque: 186 lb ft (251 Nm) at 2500 rpm
And what is the experience with the 3.9 EFI cam in the 3.5 engine with dual strombergs ?
Søren
Denmark
1967 Volvo Amazon with Rover 17D engine
Difference in output 3.5 engines
Last edited by Volvo_AmazonV8 on Fri Nov 02, 2018 9:24 am, edited 4 times in total.
Re: Difference in output 3.5 engines
Go for it, you won't be sorry. Get new lifters, too and follow the assembly and run-in procedure closely.Volvo_AmazonV8 wrote:And what is the experience with the 3.9 EFI cam in the 3.5 engine ?
Any one?
Best regards from Denmark
Søren
1967 Volvo Amazon with stock Rover 17D engine
Søren
Only difference is CR and cam, IIRC.
I cannot answer your question but those power numbers you quote seem a bit low. I have the standard 3.5 in my Landrover FC101 and it is rated at 120 HP but is a low compression engine. It is basically the same as the RR 3.5 with strombergs and does not have restrictors. What it does have are different exhaust manifolds - the 101s need more torque low down and the exhaust manifolds are designed for this so rob higher end power.Volvo_AmazonV8 wrote: ↑Sun Sep 24, 2017 9:38 am17D engine (which i suspect has a worn camshaft) Both 9.35:1 compression from a Range Rover:
So if my low compression 3.5 can produce 120 HP with restrictive exhaust manifolds, I would have thought the power from a Hi Compression engine with better exhaust manifolds would have been better than 124-126 HP.
