I have just bought a defender 90 and have the option of a 3.5L engine or a 3.9L engine, which one would be the better option.
If you chose the 3.9L option, I then have a chose of 3.9 efi and 3.9 carb?
Which v8 engine should i have
Thanks for your help, I personally have very little knowledge comes to engines. The person I have bought the defender 90 from is the mechanic that will be fitting the engine and he has offered me either one, I'm also having an automatic gearbox fitted which he has.
Re: Thanks
if the original vehicle was carb, there's quite a bit of work to go injection. Not as simply as just swapping the engine. I'd find out how much it would cost first.dio99 wrote:Thanks for your help, I personally have very little knowledge comes to engines. The person I have bought the defender 90 from is the mechanic that will be fitting the engine and he has offered me either one, I'm also having an automatic gearbox fitted which he has.
