Serpentine oil pump checking
As my new engine is nearing going back in the Capri.
What I'm after is info on deciding if the serp crank driven oil pump needs replacing or not??
Is there any way of telling??
ratwing
Post by ratwing »
According to my manual-
Max clearance between inner & outer rotor at closest together point 0.25mm
Max depth of any wear steps on edges of pump drive gear 0.15mm
Max clearance between the rotors and a straight edge across the housing 0.1mm
SimpleSimon
Post by SimpleSimon »
I have found on the serp pump rotors Tony that the wear is usually visual also i.e scored rotor tips and sometimes misshapen 8)
mine don't look that bad to be honest,
I may go with it for next year and when the engine comes out next winter for a check over change it then
Ta for the replies though guys :nw
