Oil leak?
Oil leak?
Should this have something screwed into it? Not run my engine up yet and there's no oil in it but took the plugs out today and wound it over by hand. After I noticed there was a small puddle of oil roughly under this bolt.
Yes it's where TVR put a sender for the electric oil pressure gauge. The idea was odd as the gauge indicates higher as the oil filter clogs up so when you do an oil change the gauge shows a lower reading and is a red herring worry.
This outlet is also used on some RV8's to feed an oil cooler. The return is situated on the offside of the cover just above the filter and just has a screwed in bung in it on these TVR engines and not used.
- SimpleSimon
Its a sh*t place for the sender because it sees the pressure before the filter (unfiltered oil) far better to T off the oil light pressure switch port IMODEVONMAN wrote:Yes it's where TVR put a sender for the electric oil pressure gauge. The idea was odd as the gauge indicates higher as the oil filter clogs up so when you do an oil change the gauge shows a lower reading and is a red herring worry.
- SimpleSimon
- SimpleSimon
The salvage yard you got the motor from probably removed it to sell on those OP senders are notoriously unreliableJames 33 wrote:Possibly damaged my engine due to low oil pressure too.SimpleSimon wrote:You would of emptied the sump in no time if you hadn'tJames 33 wrote:I can see how that would affect it. Just going to block it off now. Good I noticed before attempting to start the engine.
They are welcome to it then.SimpleSimon wrote:The salvage yard you got the motor from probably removed it to sell on those OP senders are notoriously unreliableJames 33 wrote:Possibly damaged my engine due to low oil pressure too.SimpleSimon wrote:You would of emptied the sump in no time if you hadn'tJames 33 wrote:I can see how that would affect it. Just going to block it off now. Good I noticed before attempting to start the engine.
