Oil cooler pipework
Oil cooler pipework
I have a rover 3.9 with a serpentine belt setup but with a distributor opening from a discovery. The timing cover is the intermediate type. I have fitted the engine into my chrome bumper mgb and am still using the old crossmember. The previous engine owner had welded over the oil filter housing and was using the oil cooler pipes with a remote filter. This suites what I am doing but the bottom oil pipe outlet is going to occupy the same place as the steering rack. Is there a tight elbow fitting I may be able to use in an attempt to keep this setup please?
My first post so forgive my ignorance on the matter.
Ok, I've now spent quite some time searching for a forged elbow with what is a m20 male from the timing cover to a 1/2" pipe outlet. I can flare the end of the 1/2" pipe and will attach a rubber hose to it. The problem I still have is to come out of the timing cover and turn direction within 31mm. No fitting seems to do the job as I have to put a straight adaptor into the timing cover to connect a female fitting into it first. Any suggestions please?
I've found a company near me www.bropel.co.uk who are happy to weld the tube if I cut it how I want it. Just a shame I can't get something off the shelf as I am concerned whether a 90 degree welded elbow in the pipe will affect flow and pressure.
https://www.dropbox.com/s/tfpfd1o5z5eyu ... 5.jpg?dl=0
Hope this link works showing the oil pipe which goes to the remote filter which I need to use on my mgb. There isn't a fitting available so this was the only option. Thanks to www.bropel.co.uk in Aldridge West Midlands UK for their help in getting the welding done.[/url]
