Is there a way of determining the original compression ratio of a 4.0 RV8 from the engine number. The block had been previously skimmed and the "dot matrix" engine number and compression ratio removed and just the engine number stamped back on.
The engine number is 55D03758A and was in a Disco 2.
Garry
Original Compression Ratio - 4.0 RV8
- russell_ram
Thanks - but the pistons now live inside the engine so not sure of the part numbers (I would need to know the Vin of the original vehicle that I do not have)
I live in Australia so is an Aussie engine.
There are plenty of listings online for comp ratio vs engine number but not for 4.0s fitted to the Disco 2. I was hoping someone might know of a list that I may have missed.
Garry
Garry
PS I have continued to look into this and came across a forum where there is a post on the very issue I have raised - Disco 2 4.0 engines starting with 55D are low comp.
So question solved but none of the RV8 engine number lists have listings for Disco 2 4.0s - RR 4.0s yes but not the Disco 2.
Garry
Garry
- russell_ram
- russell_ram
