Page 4 of 4
Posted: Wed Mar 07, 2007 11:28 pm
by Coops
mines my every day car for work in the summer, so needs to be a bit user friendly, you try driving through newbury at rush hour :(
Now im will wait for the cam verdict as im not that well clued up on cams i must admit :(
Posted: Wed Jan 21, 2009 6:25 pm
by el chapo
Hi everyone, I wonder if anyone would be to point me in the direction of a good high torque camshaft. The engine will be a 4.6 running on a hotwire EFI probably with a re-chip. This will be going into a series 3 lightweight land rover. Whilst torque is important I don’t want to limit the higher end power too much. Am I correct in thinking that in order to keep low end torque I should leave the heads standard? Does anyone have any experience of the Mark Adams chip? What sort of torque and Bhp would this setup be producing? Sorry for all the questions. Thanks James.
Posted: Thu Jan 22, 2009 10:42 pm
by badger
I have a 4.6 re-linered and bored to 4.7, hotwire efi system grafted into a disco series 2 (Thor) inlet manifold, mark adams "tornado" re-chip and a Lund LE1 camshaft. Stage 2 fully gas-flowed heads, extractor exhaust manifolds and a free-flow exhaust system. Allegedly, it's around 255bhp and 290lbft but it's never been dyno'd to prove it. In all honesty, I find the breathing to be a bit restricted above 4000rpm and I'm thinking of a change to a Viper Hurricane camshaft......
Posted: Fri Jan 23, 2009 6:04 pm
by el chapo
thanks for the info, that sounds like a lot of torque, might make my landy move abit quicker :)
Posted: Sun Feb 08, 2009 6:32 pm
by diamond
can anybody help with this number I have checked the lists and cannot find it listed. It is in a 90 that I have just bought 26G00009 CR 8.13.1
thanks in advance
Paul
Posted: Mon Oct 15, 2012 9:47 pm
by daz 104
can some one help with cam for v8 please dont no if to go for typhoon , crower 232 or steath ? has any one got spec on stealth
:( who sells the stealth ?
Posted: Thu Oct 18, 2012 8:15 am
by Muscle-Manta
Daz, V8 Developments sells the Stealth cam. http://www.v8developments.co.uk/
4.2 cam
Posted: Sat Jan 19, 2013 12:00 pm
by texpis
Hi all guess this is the place to put a cam querie. I am building up a 4.2 for my 1988 land rover 90 it has. 3.5 at the moment which is a tad underpowered ( looses power uphill in fifth ). The engine I am building is completely standard and will run on SUs, the reason is I run on LPG most of the time so seems logical to keep it as is.
My question is I have a brand new 4.2 cam on the shelf, I would like as much power as possible with the above set up should I use the cam I have or would an aftermarket one be better. I am on a tight budget so anyone have any bits sat idle let me know?
Mick
Posted: Sun Jan 20, 2013 8:48 am
Have you removed the restrictors in the inlet manifold behind the SU's?
I am not sure you would have them fitted, but they were fitted to some 90 V8's to keep the power down. Worth checking.
Posted: Sun Jan 20, 2013 9:52 am
by texpis
No the restrictions were on the series 3 stage one V8
Mick
