Distributer / Vacuum advance screw size
Posted: Thu Jan 13, 2022 10:35 pm
by Quinten
My Westfield SEiGHT is currently in the garage for winter maintenance and I don't know how long ago this has happened, but my vavuum advance is no longer part of the distributer. Both screws are missing
Does anyone know what size screws they are?
Re: Distributer / Vacuum advance screw size
Posted: Fri Jan 14, 2022 8:57 am
by paul c
I will check later on, I have a couple in the shed. One of them from an 88 Rangerover had the advance weight spring come off, I found out when the engine stopped on the way home from work one day, went to take the cap off the distributor and the top of the body moved, the weights had worn a groove right through the body and separated it into two.
Posted: Fri Jan 14, 2022 9:49 am
by Quinten
Thanks Paul, that would be appreciated. I'm hoping it is something like an M3 or M4 thread, but with everything else on the engine being Imperial, it may be more obscure than that...
Posted: Sat Jan 15, 2022 1:45 am
by paul c
One has small self tappers, the other is a torx t15 which measures 3.2mm Dia and 8mm long, so probably a 1/8 bsw or something like that. Maybe try
www.distributordoctor.com for the correct ones, they had the felt bushes I needed for mine.
Posted: Sat Jan 15, 2022 8:38 am
by Ian Anderson
Perhaps even 5BA
Conversions here
http://www.allcap.co.uk/Conversi.htm
Posted: Sat Jan 15, 2022 3:14 pm
I can say what it's not. It's not M3 or 4. M3.5 (13 amp socket fixing screws) does make a start, as do Lucas front indicator lens fixing screws from my SD1, which are UNC - something like 8-32. BA 4&6 don't fit either. So maybe 5BA?
Posted: Sat Jan 15, 2022 4:37 pm
Just get a tap and tap it to a known size, whether that be M5 or something and get a couple of nice screws for it.
Or thread lock a couple of little studs in place so you can fit nuts on.
As you say, it is more than likely some obscure imperial size at present.
Posted: Sun Jan 16, 2022 2:14 pm
by Quinten
Thanks all, and especially DaveEFI who pointed me to the UK socket screws. Perfect fit (after shortening them a little).
Posted: Sun Jan 16, 2022 2:28 pm
by GDCobra
Or use it as an excuse to ditch the Stone Age distributor with coil packs!
Posted: Sun Jan 16, 2022 2:31 pm
by Quinten
All in good time...
