Only 2 plugs on each bank firing ?
Posted: Sun Apr 05, 2020 7:39 am
Hi there, I'm new here so finding my feet.
I've got an SD1 3.5 low compression V8 with twin SU's on, it was working fine until a week ago I came back from a drive, parked it up and left it for 4 day's, when I next turned it over it would only fire on 2 cylinders from each bank, the outer 2 on one bank & the inner 2 on the other bank?
I have cleaned, gaped & checked the plugs, all firing, fuel is getting through, timing seems fine as it runs smoothly on only the the 4 cyclinders, well a smooth as it can, any ideas please, as I do not know where to fo from here.
Thanking you in advance for any help, ideas you may have.
