Ignition module wiring
Posted: Thu Nov 28, 2019 9:32 pm
by Mike V
I am fitting a rover 3.5 v8 into an mga and don’t have a wiring loom. Am trying to figure out how to connect ignition module. It has 3 connection points and would like to know which one goes where?
1 goes to :
2 goes to :
3 goes to :
Re: Ignition module wiring
Posted: Thu Nov 28, 2019 11:45 pm
by garrycol
Well the first thing is I would not use a system that has the ignition module on the dizzy. In RV8 it cooks and develops dry joints and often failure to start - get a dizzy or a modification kit that has the ignition module located away from the dizzy - early Disco V8s had the ignition module as yours is and they were consistently failing and in about 96 the ignition module was moved to be mounted near the coil on the radiator panel.
I had a new 94 Disco 1 and suffered these issues with lot of failed to proceed and took a long time to diagnose - I moved my ignition module (no kits then) and then everything was good.
Garry
Posted: Thu Nov 28, 2019 11:52 pm
Posted: Fri Nov 29, 2019 11:23 am
by Mike V
Thank you, very helpful! Does NC mean not connected?
Posted: Fri Nov 29, 2019 1:03 pm
Mike V wrote: ↑Fri Nov 29, 2019 11:23 am
Yes. It is actually a ground, and I'd guess used where screened cable is needed.
