Megasquirt - RusEFI
Re: Megasquirt - RusEFI
Would just point out that the MegaSquirt manuals - accessible from the MS forum - are extremely comprehensive. But because of that can take some reading - but do contain pretty well everything you will ever need to know.
Just for information, the fuel pump relay driver on the V3 board, which is a ZTX 450 transistor, is the most common fault I've fixed on that board. No idea why, as I just get the board for repair, so can't examine the installation. That transistor is more than adequate for the load of a relay coil and has flyback protection, so my guess is the actual transistor maker may be at fault with poor quality control. I generally replace it with a 2N2222 as I have hundreds of them. :D
