How much wiring can I lose?
Posted: Mon Oct 02, 2017 5:13 pm
I'm nearing the end of a 3.9 rv8 rebuild which I would like to run with the original 14cux injection mainly as I have it and it may be interesting/satisfying to get it working, the engine is going into a cobra so I'm losing the air con andpower steering, my gauges are etb classic ones. The question is how much of the loom and sensors can I get rid of?, I think I need the road speed sensor which I could run off the speedo sensor?, do I need the fault code/obd wires from the ecu? Can I just cut out the wires for the air con and cruise control?, as I won't be running cats I'll change the tune resistor does that mean I don't need the lambda wires?, . Thanks in advance for any advice
Roger
Roger
