Gents, I'm needing to buy the 4way Quad Connector for a TVR Chimaera/RV8 engine; these are the Delphi type connectors with the light green weather seals.
The Q? is, do I need the LMA868 8Amp or LMA869 20Amp connector?
Stepper Motor LMA 4way Quad Connector
Ah. Think the one for the hotwire may be different. Mine came from a hotwire loom complete with the cables, so I didn't have to fit new terminals.
The main body is 17mm sq, and the overall length 40.4mm
The actual contact 'square' is 14mm to the outside of the plastic sleeves.
The connector body has PEO 30 printed on it.
David, are your eyes a bit skewed? It should read P.E.D. with the #34 above left to the P.E.D. Your dimensions are similar, mine too came from an original loom but the tag clip has broken...hence a new one's req'd. The TVR guys on PH believe it's only 8A...which makes sense as I can't believe a stepper motor would draw up to 20A.
Suppliers found include ExtraEFi, DemonTweeks, Burton Power and Rally Design
That's a way of putting it.v8250 wrote:David, are your eyes a bit skewed? It should read P.E.D. with the #34 above left to the P.E.D.
You're partially correct. Mine reads P E O or D - difficult to be certain. But definitely 30 beneath it. But that might just be a batch number.
The MS chip which drives it can't deliver 20 amps either.
The only new one I came across (Extra EFI) came with a pigtail - not what I'd want, since I don't like to join cables unless essential. And like to choose my own cable colours too.
Not too keen on pigtails either as they add one too many connections, though I suppose Extra EFI are being good boys in supplying an easy install. Have ordered from Rally Design for the princely sum of £7.05+VAT including all the terminals and rubber wire plugs.DaveEFI wrote: The MS chip which drives it can't deliver 20 amps either.
All, FYI here's the link to Rally Design connectors...
http://www.rallydesign.co.uk/product_in ... ts_id=2499
