Better Megajolt Map
Better Megajolt Map
Dear all - I am running the standard supplied mega jolt map on my 5.0 Landy v8 on and Eddie 600 and performed manifold and stage "3" heads. Does anybody else have a better map- I run mainly 97-99 octane and a 10.2-10.4 CR - want to reconfigure this afternoon - if no maps available any general tips at all??
I know your right mate, but I will have to change the wheels (too knobbly apparently) and just wondered if I could look at somebody else's map I could see how they optimised it beyond the standard - think more advance in the mid range when under low to moderate load may help
I've run the dakar on a dyno twice now - i run 35" general grabber mud terains.
picture:
http://www.mez.co.uk/dcam/DSCF3079.JPG
picture:
www.marcosmantula.com is my toy.
Its going off for a interior trim very shortly and when it's back home i plan to take the car to,
http://www.lloydspecialistdevelopments.co.uk/
who have some experience of Megajolt so hopefully will do a good job, car has stage 3 heads, stealth cam and was built up for me by V8 Developments (and it only weighs 820kgs)
Regards,
Martyn....
Regards,
Martyn....
Not sure how to post photographs on here but have had my car tuned today and uploaded a magajolt map and dyno results on my blog if that is any use to you,
Www.marcosmantula.com
Regards,
Martyn...
Regards,
Martyn...
The all out advance looks very conservative to me, so I'd guess you'd have to add the trigger offset to it for the true reading.
Wasted spark should show the same as sequential using a timing light - but some posh lights - the dial in advance ones - can get confused by it. I had to go back to my old one to get any reading at all.
