Rover SD1 Clutch Slave Fitting
bigdawgv8
Post by bigdawgv8 »
Hi All,
I’ve just bought a genuine SD1 clutch slave cylinder off the Bay of E.
The port for the flexi pipe appears to be about 1/2 inch diameter but isn’t unf so assuming it’s metric fine?
Can anyone confirm the thread size please?
Thanks for the help.
Building 2 V8 Minors - double trouble!
richyb66
Re: Rover SD1 Clutch Slave Fitting
Post by richyb66 »
Pretty sure it's 7/16" UNF
harvey
Post by harvey »
richyb66 wrote:
Mon Dec 10, 2018 9:11 am
It's not UNF, because I used an SD1 slave cylinder on a P6B 3500S LT77 conversion and I had to fit the SD1 fitting on to the end of the clutch hose.
I'd say it's a fine Metric.
I'm fairly sure all the SD1 brake etc fittings are metric. But there is a UNF size very easily confused with it, and even has the same TPI, so sort of fits.
ged
Post by ged »
M12 X 1 definitely as I've just measured a spare.
DEVONMAN
Post by DEVONMAN »
7/16" unf is the size of the thread on the very similar cylinder used on Defenders etc.
Genuine SD1 cylinders have an M12 thread.
richyb66
Post by richyb66 »
I'm amazed anyone at rover in the 70's knew what a metric thread was.
When I fitted my helix clutch last winter I had to swap the SD1 Master Cylinder for a bigger bore Defender V8 one because you couldn't physically press the clutch pedal. The inlet sizes were different so I ended up getting a new hose made - they don't make these things simple do they?
The SD1 is of course BL rather than Rover, and was designed when metric was coming in. Pretty well all of it is metric, except the RV8.
