Mcleod RST Clutch Advice,
Evening All,
Just taken delivery of my New RST twin plate clutch,
there's an adaptor ring that bolts to the fly wheel, that carries the first clutch plate, then the second plate and cover bolt to this,
Will I need to use locating dowels for the adapter ring???
Instructions are a little vague in the box lol,
I need to get the flywheel drilled to take the new adapter ring/clutch so wondered if it needs drilling to take dowels too?
And it looks like the original cover bolts are used to hold the adapter ring to the flywheel,
I did a quick rummage on the net and found this.....
4.6L and 5.4L Ford Modular engines require the installation of the supplied dowel pins (3) into the
factory flywheel. GM LS engines require the installation of 2 of the supplied dowel pins into the
factory flywheel.
http://www.cjponyparts.com/skin/fronten ... cleod3.pdf
Yeah that paperwork is in the box
But no dowel pins which made me wonder as its to go onto the rover flywheel what you do.
JP.
Post by JP. »
Don't think its needed.
As I remember, I had to remove my dowel pins when converting to the McLeod 10½" Street/Strip kit ( now sold as HD kit ). Never replaced those dowels.
'73 Ford F250, 6.7ltr V8
Building a GT40 mk2
Hi JP.
Did you use the o/e size cover plate bolts?
JP.
Post by JP. »
I used the ones RealSteel suplied. BY1500, bolt kit for McLeod pressure plate.
Building a GT40 mk2
ahh ok,
I may go that route too then,
otherwise I'm going to have to use the o/e bolts and locator dowels.
I see the 3/8 bolts have a locating shoulder to do away with the locating dowels
Right,
I'm getting nowhere fast,
Spoke to RS today and the guy I spoke to didn't have a clue what bolts are needed to hold the adapter ring to the flywheel.
He said it may end up being a special order item,
and will ring me back, with a price :?:
Realsteel have gone down hill fast
Called them Friday asking about the clutch cover bolts, and as previous post were going to call back,
Nothing again today,
Email to Mcleod in the USA and get an answer back in half an hour,
