The V8 Owners Forum - Forum Index The V8 Owners Forum -
Welcome to the well-known V8 Owners Forum, no matter what you drive if its V8 Powered you'll be made very welcome.
 GarageGarage   1/4 Mile Table1/4 Mile Table
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
solenoids
Post new topic   Reply to topic    The V8 Owners Forum - Forum Index -> Nitrous Oxide Area
View previous topic :: View next topic
Author Message
JSF55
1955 Ford Popular 103e
PostPosted: Thu Feb 17, 2011 6:03 pm    Post subject: solenoids Reply with quote
Do they have to be mounted upright? and is it possible to use flexi lines to supply to the jets so they can moved out of the way a bit Confused
_________________
So thats where it went !
Back to top
View user's profile Send private message Visit poster's website
1975 MG MGB GT V8
PostPosted: Thu Feb 17, 2011 8:17 pm    Post subject: Reply with quote
They can be mounted any way really. There are some basic rules for the ay the fuel solenoids should be fitted. mainly to ensure air naturally vents out of the fuel line before the solenoid and the solenoid itself.
What system are you using ??
Got any pics??
_________________
Back to top
View user's profile Send private message Send e-mail
JSF55
PostPosted: Thu Feb 17, 2011 9:17 pm    Post subject: Reply with quote
Hi Perry, it's an edelbrock one, but the solenoids stick out the front and back of the carb, noticed on ebay a kit with flexible lines, i'd like to mount them more to the rear possibly under the coil packs ?
_________________
Back to top
1975 MG MGB GT V8
PostPosted: Fri Feb 18, 2011 8:29 pm    Post subject: Reply with quote
OK!
So its a sniper or cheater kit etc...
Is that a pressure reg between the fuel filter and the solenoid??
If you have tapped off the 5psi supply for the carb from the same pump that wont be needed. Or do you have a separate pump running higher psi for the nitrous fuel supply ??
The main thing to think about is fuel delivery. If you run nitrous at 800-1000 psi then the speed of that nitrous will get to the plate in a heartbeat. But petrol running at 5-6 psi will take an age to get to the plate. You need to make sure that the petrol and gas hit at the same time, or even make sure the petrol gets there a bit before the gas??
Give us some more info on:
Fuel pressure.
Nitrous pressure control (bottle heater etc)
How much gas you want to flow.
How long is the line from nos bottle to engine.
Perry
_________________
Back to top
JSF55
PostPosted: Fri Feb 18, 2011 9:03 pm    Post subject: Reply with quote
Hi perry, yeah sniper kit, i only wanted to move the solenoids as they look pant's where they are ! but as your asking Laughing seperate supply from the tanl through a facet solid state pump... err 6 psi ? to the regulator and filter in 8mm pipe. nitrous line is standard kit length , about 4m ? and the bottle just sits in the boot empty Shocked i've got a rebuilt engine going in towards the end of next month and that will need running in, it'll probably the end of september at the hot rod drags before it's used, oh it's set for a 50bhp shot ..... sh!t i've already asked that Shocked
http://www.v8forum.co.uk/forum/viewtopic.php?t=7850&highlight=nitrous
_________________
Back to top
1975 MG MGB GT V8
PostPosted: Fri Feb 18, 2011 9:23 pm    Post subject: Reply with quote
OK!
You need to go back to basics now. And you will need to do some basic flow testing. I know this sounds like a bit of a faff. But if you want the best results then you need to get this poop sorted before you go on track really..
Ditch the fuel pressure regulator for a start.
Then fit a fuel pressure gauge in its place.
Then pull the plate of the engine so you can flow fuel through the fuel jet and out of the spray bar into a big jug.
You need to operate the solenoid and see how much fuel flows into the jug in 10 seconds and also monitor the fuel pressure on the gauge while doing this.
Make sure you have purged all the air out of the fuel line up to the solenoid before you do this test.
Make sure that you do the test for a proper 10 seconds and let us know how many ml's of fuel you flowed and at what pressure. This will tell us the actual hp amount of fuel you have flowed.
Once we know how much fuel you can flow on the 50hp fuel jet we can talk about the nitrous side of the system..
If you have the stock 4metre -4 size braided hose with the bottle in the boot you will need to make sure that the bottle pressure is at least 850 psi before doing a flow test on the nitrous.
Perry
_________________
Back to top
JSF55
PostPosted: Fri Feb 18, 2011 9:33 pm    Post subject: Reply with quote
Cheers perry, i'll come back to this later in the year, no point on starting something i can't finish ! i just remembered there was a hold up on the SPV which left me with no time to finish it Sad
_________________
Back to top
1975 MG MGB GT V8
PostPosted: Sat Feb 19, 2011 7:02 pm    Post subject: Reply with quote
SPV ??
_________________
Back to top
JSF55
PostPosted: Sat Feb 19, 2011 8:17 pm    Post subject: Reply with quote
Safety pressure valve? maybe there called something else?
_________________
Back to top
1975 MG MGB GT V8
PostPosted: Sun Feb 20, 2011 8:24 pm    Post subject: Reply with quote
Are you talking about the wizards of nos SPRV??
This will replace your old bursting disk on the bottle valve.
_________________
Back to top
1986 Ford Capri
PostPosted: Sun Feb 20, 2011 8:45 pm    Post subject: Reply with quote
thats what i must do at some point,
change the rupture disc to the SPRV valve.
_________________
Rotrex C38-91 supercharger and Cossie RS500 Intercooler @ 14psi of Boost. 404 RWHP, (4.6)
New Forged 4.8 V8 kitted out with the dogs Cajones of parts and a procharger D1SC. 2017 Very Happy
Back to top
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
JSF55
PostPosted: Mon Feb 21, 2011 6:14 am    Post subject: Reply with quote
Yep spv. . . spectrum pursuit vehicle Laughing there was no rupture disc fitted, it had a gauge screwed in instead Shocked so wouldn't chance it till ia arrived a little late Sad
_________________
Back to top
1975 MG MGB GT V8
PostPosted: Mon Feb 21, 2011 7:35 pm    Post subject: Reply with quote
Good move mate!!
A gauge instead of a safety valve Laughing
I've converted a few of my bottles to sprv's now.
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic    The V8 Owners Forum - Forum Index -> Nitrous Oxide Area All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Make payments with PayPal - it's fast, free and secure!
Copyright www.v8forum.co.uk 2006. All Rights Reserved,
Forum Disclaimer: Any posts in the V8 Forum are posted by individuals acting in their own right and do not necessarily reflect the views of the owner, administrators or moderators.
