Twin SU plumbing and throttle
Spoke with Jim from JRV8 today in Ireland. What a helpful bloke freely gave me loads of advice about V8s. Basically he said the same need to connect up the crankcase breather system properly.
He can supply the parts too (which I have discovered are quite hard to find). Highly recommended.
If theres a harder way to do it I'll find it!
Ok, so conected up the pipes like Jim and others suggested.
Run to normal temp.
Still ticking over too fast,
So.....I slow it down with the now effective idle screw. then it tries to die......... eventually. So take it up a millimeter turn or so and go for a run. Get home and its revving its head off again. So I sat there on the engine turning each SU down mm by mm and trying again each time its either too slow that it wants to die or it revs its head off.
Jim did say I might need to adjust the mixture but I wasn't sure which screw to turn and then I ran out of time/daylight.
Messing with the mixture and other settings in my previous (80's) experience always cocks it up unless you:-
A. Know what you are doing (I don't)
B. Have the tools (Again I don't)
So me thinks I need a V8 specialist near me?
Run to normal temp.
I am pretty sure you have over run poppet valves in the throttle plates on that version of the SU, lift the piston and have a look, if they are there then remove the carbs and solder them shut, you certainly have the symptoms of poppet valve spring failure! I have done a couple of recent posts on poppet valves so have a hunt. Once you are certain you have sorted this issue then set the idle on the idle screws, with the cross linkage disconnected and the throttle cable removed, once it is stable and correct re attach the linkage and throttle cable checking all the time that you are not effecting the idle and that when you operate the throttle the pistons rise together. now set up the mixture as per the Hains manual, any Hains manual for any rover/layland car with 2 SUs will have the procedure, but the one for late model V8 range rover would be best in your case.
Thanks Mike.
I'm sure it does have the poppet valves. Think I saw them when I looked in there. Saw a post somewhere on here (was probably yourself) suggesting to solder them shut, and I was wondering whether to do that.
Can it be done with the carb on the car?
not that long, 5 minutes to take the air filters off, 10 minutes to clean things up before stripping off the manifold, 10 min to get the linkage off and 10 for the 4 nuts each side holding the carbs on. . . 15 minutes each carb to take the bottoms off the float bowl each side and wash them out with warm water and you are ready to go, 5 min to solder them shut and about 30 min each to put them back together and back on the engine what 2 1/2 hours 3 with a stop for a cup of tea half way through for the whole job.
While they are in your hands you can save time on later set up and tune by setting the jets to the starting position and setting the idle position of the throttle plates the same on each carb with a feeler gauge, much quicker with the carb in your hand.
best regards
best regards
I must confess the first thing I did when I installed the boxer manifold on my first range rover was to convert all 4 SUs to plain throttle plates. However I was trying to get this chap a solution that did not involve any more dismantling and setting up than necessary, and centering SU throttle plates can be a fiddle, as can putting the fixing screws back in the throttle shafts!
Did some more tinkering, topped up the dashpots, checked the poppet valves were not stuck and stuck a bit of lube on them. Shoved some redex in the fuel and then just sat there in the engine bay tweeking it bit by bit. Now it seems to have settled down, and burbles quite nicely.
Thanks for all the advice.
- Helpful or Confused
