hello all,
My 4.6 block as been through some major work, the deck has been skimmed and I'm now going to be using 1mm thick head gaskets.
So looking at a dry assembly of the head, tappets & rocker assembly, my adjustable push rods look so close to the bottom nut, so not really leaving any room for major bottom length adjustment.
Was thinking of making them smaller in length by 4-5mm, as threes still loads of adjustment in the screw part to make up for this.
Presuming I can remove the bottom ball end and remove the amount required in a lathe?
anyone done this?.....or am I about to do more worse than good?
scott
shortening adjustable pushrods
- Seight-V8
- Seight-V8
