Lazy V8
Mike Francis
Lazy V8
Post by Mike Francis »
Hi Guys, new member to the club :D and i hope you guys can help me i have a vauxhall FD ventora which is now fitted with a 3.9 disco V8 it has electronic ignition and stainless steel twin exhaust system with 1 silencer for each side and its 2.5" pipe, carb is 4 barrel weber 500 Edlebrok ok so all new plugs and leads and running through LT75 5 speed box all sounds good BUT!! now don't get me wrong i'm not some tear arse kid but my car is slow to pull away, there is no way you can wheel spin it and once its driving along the road its lake a lazy plodder, it gets up there just in no hurry to do it you deffo aint going to re-enact any scene's from Bullet ! like i said i'm not after being cock of the block and razzing round everywhere but i do want the car to drive like its fitted with a V8 motor any ideas on what's going wrong??
Ignition timing?
Darkspeed
Post by Darkspeed »
Biggest issue I find with almost all engines reporting low power or lack of performace is the throttle not achieving wide open.
Then just follow the usual logical approach
Health check - compression etc.
Electrics - big fat spart in the right place - and leads on the right pots
Fuel
4.5L V8 Ginetta G27
M60 Dude
Post by M60 Dude »
What rear end gear ratio do you have I have fitted shorter ratio axles before to get things going im not saying this is the problem thought just thought.
Hope you find the information to sort your problem out 👍🏻
All the above and also the possibility of a worn out camshaft.
DEVONMAN
Post by DEVONMAN »
If the vacuum advance is connected then disconnect it and set idle timing to 12 degrees.
Rover distributors don't like the amount of vacuum given by the weber 500.
