The V8 Owners Forum - Forum Index The V8 Owners Forum -
Welcome to the well-known V8 Owners Forum, no matter what you drive if its V8 Powered you'll be made very welcome.
 GarageGarage   1/4 Mile Table1/4 Mile Table
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
Bit of a result ......
Post new topic   Reply to topic    The V8 Owners Forum - Forum Index -> Rolling Roads And Dyno's
View previous topic :: View next topic
Author Message
seight
2007 Westfield Seight
PostPosted: Sat Mar 28, 2015 2:08 pm    Post subject: Bit of a result ...... Reply with quote
..... it's been a long time coming but I'm one step closer to getting on the road - I trailered my Westfield to a rolling road yesterday.
314.8 BHP @6100rpm
320 FT/LB @4500rpm
from my RV8 4.2ltr (+.020), MC1 cam, 10.2:1 CR, Stage III heads, ported hotwire manifolds, ACT carbon plenum, 4.6 throttle body, MegaSquirt 2.
Needless to say I am well chuffed from an engine I built with limited knowledge. So a big thanks to everyone who answered any of my dumb questions.
Only pain was my lambda sensor gave up Sad so it's been mapped without it.
IVA test next ! IT's a '92 block so I with 90ppm HC and 1 ish %CO it should be fine Smile
Mike SmileSmileSmile
Back to top
View user's profile Send private message
JJMclure
1989 Vauxhall Carlton
PostPosted: Sat Mar 28, 2015 5:17 pm    Post subject: Reply with quote
Yep your emissions should be good - good luck!
_________________
don't nibble on the barrel, pull the trigger!
Back to top
1986 Ford Capri
PostPosted: Sat Mar 28, 2015 10:01 pm    Post subject: Reply with quote
where did you go mate?
_________________
Rotrex C38-91 supercharger and Cossie RS500 Intercooler @ 14psi of Boost. 404 RWHP, (4.6)
New Forged 4.8 V8 kitted out with the dogs Cajones of parts and a procharger D1SC. 2017 Very Happy
Back to top
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
seight
PostPosted: Sun Mar 29, 2015 9:30 am    Post subject: Reply with quote
Hi Coops,
I took it to http://www.dyno-tech.co.uk which isn't too far from me.
I'll get the map and plots uploaded later if anyone's interested.
Mike Smile
Back to top
Blown v8
PostPosted: Sun Mar 29, 2015 2:12 pm    Post subject: Reply with quote
Yep,post them up Very Happy
Back to top
seight
PostPosted: Sun Mar 29, 2015 3:47 pm    Post subject: Reply with quote
Back to top
Cobratone
Is a Spanner
PostPosted: Tue Mar 31, 2015 3:27 pm    Post subject: Reply with quote
Quick question, why do your fuel and ignition load percentages not start at zero?
_________________
Big Tone
www.cobratone.co.uk
Back to top
View user's profile Send private message Visit poster's website
r2d2hp
PostPosted: Tue Mar 31, 2015 5:09 pm    Post subject: Reply with quote
I have a question as well. Why did they use 3rd gear as I am led to believe that would have a positive effect on the results according to Dave Walker.
He has always done my runs in 4th eg 1-1
Back to top
seight
PostPosted: Tue Mar 31, 2015 7:10 pm    Post subject: Reply with quote
That's interesting. Someone would have to explain the physics to me! 1:1 in the gearbox then you still have the diff ratio and tyre size determining your road speed.
A quick bit of googling seems to suggest there's all sorts of opinions. One guy on pistonheads seemed to get better figures in 4th.
Confused
Back to top
r2d2hp
PostPosted: Tue Mar 31, 2015 7:26 pm    Post subject: Reply with quote
Dave Walkers site is quite informative and based on his experience over the past 30 years http://www.emeraldm3d.com/rolling-road.
Section "BHP at your wheels" discusses why BHP goes up when a lower gear is used
Back to top
seight
I have no idea Embarassed
I'm using speed density for both fuel and ignition if that helps. Confused
Back to top
Cobratone
Is a Spanner
PostPosted: Tue Mar 31, 2015 7:35 pm    Post subject: Reply with quote
I use speed density too and my tables start at zero which is where the car idles at as there is no load on the engine. All my cruise and the majority of my driving is done with a load less than 15% so not sure why yours would start there, unless I have it wrong??? Anyone else got an opinion??
*addition* I'm actually running AlphaN, not speed density which explains why I was confused. Sorry Embarassed
_________________
Big Tone
www.cobratone.co.uk
Back to top
seight
PostPosted: Tue Mar 31, 2015 7:51 pm    Post subject: Reply with quote
I dunno Tone.
My understanding was that speed density is about manifold air pressure etc and even at idle you'll have something. If you use TPS position then you would have a zero. But I may be talking carp.
Back to top
Cobratone
Is a Spanner
PostPosted: Tue Mar 31, 2015 7:54 pm    Post subject: Reply with quote
seight wrote:
I dunno Tone.
That explains everything Mike, I'm talking out my arse Embarassed I run AlphaN (TPS) not speed density! My mistake, sorry for the confusion Wink
_________________
Big Tone
www.cobratone.co.uk
Back to top
seight
PostPosted: Tue Mar 31, 2015 8:28 pm    Post subject: Reply with quote
Interesting read but it also suggests losses are greater at higher speeds so although you get a lower wheel bhp you add on more for transmission losses in order to guesstimate flywheel bhp.
If you do the run in a lower gear and lower speed you add less on.
I'm going to spend hours reading this stuff now you've started Laughing Laughing
Back to top
Display posts from previous:
Post new topic   Reply to topic    The V8 Owners Forum - Forum Index -> Rolling Roads And Dyno's All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Make payments with PayPal - it's fast, free and secure!
Copyright www.v8forum.co.uk 2006. All Rights Reserved,
Forum Disclaimer: Any posts in the V8 Forum are posted by individuals acting in their own right and do not necessarily reflect the views of the owner, administrators or moderators.
