Overfinch
V8 Only Please,
Spongo
Overfinch
Post by Spongo »
Hi there just joined the forum, mine is a Range Rover 630R or otherwise known as a money pit :lol: Great car but it has spent way too much time in the garage in bits :(
How do you upload pictures?
Spongo
Post by Spongo »
Finally got round to some picture of mine here as well
And here is the "important" one :twisted:
What I like the best is that it looks pretty much standard a bit like a sleeper save for some tell tale Overfinch badges
MS2 with switch MAPS for LPG
Techedge Wideband Sensor
harvey
Post by harvey »
Spongo wrote: What I like the best is that it looks pretty much standard a bit like a sleeper
Don't they just...... I went out to front lift one using my spec-lift not knowing what it was and it nearly gave my old truck a hernia getting it off the ground...:lol: :lol: :lol:
Towing it back was pretty entertaining as well.
(PS I took the rear prop off before anyone asks).
harvey wrote: (PS I took the rear prop off before anyone asks).
You don't need to - you can put the transfer box in neutral - Procedure is explained in owners manual (pulling a fuse IIRC)
Edit:
http://www.landyzone.co.uk/land-rover/c ... wed.97799/
Nice.
harvey
Post by harvey »
Edit:
That's soft towing (on a rope or pole), you have to disconnect the prop to speclift tow them. It even says so on the link you posted:
"All P38's must be put into transferbox neutral before being towed on all four wheels, and must have the prop shaft disconnected from the axle on the ground if being towed with just two wheels on the ground, .e.g on a dolly or spec lift".
Spongo
Post by Spongo »
Surprisingly the SBC engine is only about 30kgs heavier than the rover, this assumes that it has aluminium heads and water pump which mine does.
Towing a P38 is basically a pain in the derrier :)
Return to “Your Cars”
