The V8 Owners Forum - Forum Index The V8 Owners Forum -
Welcome to the well-known V8 Owners Forum, no matter what you drive if its V8 Powered you'll be made very welcome.
 GarageGarage   1/4 Mile Table1/4 Mile Table
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
Head confusion - pocketed piston
Post new topic   Reply to topic    The V8 Owners Forum - Forum Index -> Exhaust, Cylinder Heads, Fuel And Intake Area
View previous topic :: View next topic
Author Message
southernd
PostPosted: Tue Oct 03, 2017 10:26 pm    Post subject: Head confusion - pocketed piston Reply with quote
I've read the forums extensively but I'm just trying to get my head around what I need to do.
I have a standard Rover 4.6 V8 in a 920kg car. I want to upgrade the following over the winter:
Camshaft
Heads
I have a spare couple of heads for the 4.6 which I wish to upgrade to the Stage 3 RPI head kit as well as some port work. I've also looked at the cams however I see there is an issue with flat pistons(unlike pocketed in TVR).
So here is the confusion. If I put larger valves in the head are they any more or less likely to come into contact with the piston if I used a mild cam such as the MC1 or do the clearances remain the same? I'd obviously like to avoid putting in pocketed pistons if I can Very Happy
Many thanks for your help!
_________________
MX5 4.6 V8
Previous of many SD1's back in the day!
Back to top
View user's profile Send private message
gd302
PostPosted: Wed Oct 04, 2017 8:14 am    Post subject: Reply with quote
The MC1 gets rave reviews from what ive read about it, im not sure on the specs but the Tvr guys really rate it. Im currently doing a cam refresh on my 4.0 engine and its top of my list at the moment. (no cut outs)
Their stealth cam is also reported to be very good but requires cut outs.
Ive also read good reports about crower cams but ive had no success in getting any info on them.
Im no expert but if you don't go mad with the heads its the cam lift specs that cause problems with piston contact.
V8 Developments seem to be the most highly regarded suppliers and are one of the only ones that bothered to reply to my questions, they are worth a call and a chat.
_________________
1995 TVR Chimaera 400 With tweaks
Back to top
southernd
PostPosted: Wed Oct 04, 2017 8:50 am    Post subject: Reply with quote
Thank you, I'll give them a call Very Happy I had read on the Crower 50232, they're much better priced than most of the others I've seen($200 against 535).
http://thebritishcar.com/archive/index.php/t-451.html
From what I read most need pocketed pistons though Sad
_________________
MX5 4.6 V8
Back to top
gd302
PostPosted: Wed Oct 04, 2017 10:39 am    Post subject: Reply with quote
Yes the full cam kit is about 500 including everything to do the job.
No point going too wild on a light car.
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic    The V8 Owners Forum - Forum Index -> Exhaust, Cylinder Heads, Fuel And Intake Area All times are GMT
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Make payments with PayPal - it's fast, free and secure!
Copyright www.v8forum.co.uk 2006. All Rights Reserved,
Forum Disclaimer: Any posts in the V8 Forum are posted by individuals acting in their own right and do not necessarily reflect the views of the owner, administrators or moderators.
