Page 2 of 4
Posted: Wed Sep 15, 2010 8:51 am
by Darkspeed
I think I see where you are coming from now - you have the big issue with Panhards and leafs - they just do not go together as they get in each others way when looking to lower the RC.
Not a great deal you can do with the back end that you have already done without a complete redesign with a coilover based approach. The Mumford offers a solution that will fit within the leafs and have an effect - although I would maintain that the result will be compromised due to the nature of the leaf suspension BUT it does allow massive scope for playing
By the way is it entry or exit oversteer or just plain all the way through ?
Andrew
Posted: Wed Sep 15, 2010 5:36 pm
by mgbloke
mgbloke wrote:Andrew
My main reason for choosing the Mumford is to lower roll centre to hopefully reduce understeer. If it doesnt work I will revert back to a panhard rod.
Mark
Sorry should read oversteer.
The back end is always too ready to step out.
Posted: Fri Sep 17, 2010 5:54 pm
by mgbloke
I am going to get the bellcrank and pivot made up and then make a full size model to see where it is best to put the mounting points.
Also I can plot the sideways movement if any.
my last event is 23rd Oct so will tear it all apart after that.
Hopefully this will be a big improvement over the Panhard.
Mark
Posted: Sun Oct 03, 2010 9:26 pm
by mgbloke
Having made a full size model I have decided that this probably wont work with leaf springs. When in roll the axle actually moves sideways about 30mm.
Im not sure my composite springs can withstand twisting, sideways movement and do their suspension job without having problems.
I will probably do a 4link coilover conversion at a later date and use the mumford then.
Posted: Wed Feb 19, 2014 8:38 pm
by mgbloke
Well I am now forced to change from the composite springs and a custom coilover setup is well under way.
I have spent hours mocking up different setups inc panhard rod Watts and Mumford linkages.
Still going with the mumford and have started to make the linkage.
some pics.
soon be ready for a trial fit .
Posted: Tue Jun 17, 2014 7:16 pm
by mgbloke
Well after a LOT of work I have tested the new 4 link trailing link suspension with the mumford link and it seems to be very good on the road. The car feels slightly more refined. Tried some roundabouts at speed and couldn't make it break loose.
Now to try it on track.
I originally built it with #150 lb springs but changed to #175 lb.
Also I have the option to lower the rear roll centre.
Mark
Posted: Sun Jun 29, 2014 1:33 pm
by mgbloke
a few pics.
Posted: Sun Jun 29, 2014 8:08 pm
by mgbv8
Looking good mate
Posted: Sun Jun 29, 2014 8:53 pm
You know you find the strangest things under the back of MGBs holding the back wheels apart!
best regards
Posted: Mon Jun 30, 2014 6:53 am
by chodjinn
Awesome work mate.
Posted: Mon Jun 30, 2014 5:16 pm
by mgbloke
Thanks guys, its nice to be a bit different.
Here is a mock up clip.
Posted: Sun Jul 13, 2014 7:54 am
by mgbloke
On Friday 11th July the new suspension was tested on track at castle Combe. I immediately noticed how much the rear gripped under power out of the corners and how stable the car felt. For the second session I clicked the shocks harder which further improved the performance.
I had 5 sessions of 15mins on track.
Really delighted with the result and think with some fine tuning it will be awesome and of course a lot stronger than the composite springs that it replaces.
Another thing that I noticed was much less tyre wear.
Why are more people not using this????
Mark
Posted: Sun Jul 13, 2014 10:18 am
by chodjinn
Because they're sheep.
Glad it's worked out so well, you obviously did your research and designed it well. What shocks are you using?
Posted: Sun Jul 13, 2014 10:29 am
by mgbloke
Had the shocks purpose made by Protech in Melksham. Nice quality units in aluminium. only single adjustable though.
Posted: Fri Sep 26, 2014 9:43 pm
by mgbloke
I had an issue with the axle tubes being bent due to welding on the bracketry. Now straightened and fresh CW & pinion along with the quaife serviced.
Just done one more trackday and I have to say it is quite remarkable how this contraption keeps the rear so planted, so much so that I am having to change my driving style to suit. Well chuffed and looking forward to some extra power soon. Well worth all the work.
