Page 1 of 2
v8 3.9 lpg ignition timing
Posted: Sat Apr 09, 2011 12:12 pm
by welshphill
hey guys in my attempts to sort out another problem i messed with my ignition timing on my 95/M 3.9 v8 discovery...
i've reset it, using a timing/strobe light to bang on the timing mark (crank pulley) but she feels a little "down on power" not as responsive now when running on lpg (which i do almost all the time, petrol is just used for start-up)
can anyone suggest a good ignition setting for optimum lpg running, bearing in mind all i can find is a large 'notch' on the timing/crank pulley???
cheers muchly, welshy
Posted: Sat Apr 09, 2011 2:16 pm
by softdash3.9
If you clean up the pulley there should be timing marks.
I run my RR Classic 3.9 on 16 deg BTDC base timing for LPG with vac disconnected.
16 deg is beyond the std timing @ 12 deg, I use a paint marker to mark TDC and the timing marks
Posted: Sat Apr 09, 2011 5:00 pm
by welshphill
Posted: Sat Apr 09, 2011 6:33 pm
by Pocket rocket
Once you've uncovered the markings, smear a bit of tippex over them and then wipe off - should leave the marks bit more visible
Posted: Sat Apr 09, 2011 6:40 pm
I used to just turn the distributor until I was happy with performance......
Posted: Sun Apr 10, 2011 6:29 am
by Quagmire
I also used to do what Chris suggested.
Turn dizzy to advance a bit, then go for a drive ON PETROL. Make sure that the thing is not pinking like mad.
Keep advancing until you are only getting a tiny bit of pinking under heavy load on Petrol. I had mine set so that I could drive around any pinking on Petrol just by shifting down if needed.
Now you have set the timing as far advanced as possible to run LPG, without making the car unusable on Petrol either.
Posted: Mon Apr 11, 2011 11:36 am
by welshphill
Posted: Mon Apr 11, 2011 6:52 pm
The distributor is probably one tooth out on the camshaft then.
Posted: Tue Apr 12, 2011 12:18 pm
by welshphill
MMMMmmmmm
when i first picked it up the dizzy cap was on backwards so i suspect the last person to touch her was a bit of a bodger/didn't have a clue...
how would o go about getting the dizzy spot on???
Posted: Tue Apr 12, 2011 5:52 pm
welshphill wrote:MMMMmmmmm
The technique I use is this:
1. Get the engine to TDC on no. 1 on the firing stroke. You can get it to TDC with a screwdriver in the spark plug hole. You check it's on the firing stroke by making sure that both valves on no. 6 are open a crack (you have to remove the rocker cover to do this).
2. Fiddle about with the distributor / oil pump drive until when the distributor is fully home, (it turns as you slide it in), the little spoke on the 8 spoked thing is pointing exactly at the little spiked pickup. Also check that the distributor is in the middle of it's adjustable range, i.e. not hard up against the water pump or head.
Then turn the distributor body a tadge clockwise, put it together and fire it up. Then you should have enough adjustment.
Also make sure you've got the right sort of distributor. I forget whether the SD1 version means you have bugger all adjustment on a Range Rover, or the other way around, but it's worth checking.
Posted: Thu Apr 14, 2011 9:10 am
by spratty
can you not work out that no. 1 is on the firing stroke by checking if the rotor arm is pointing at least vaguely to where the HT lead for no. 1 would be? this would save taking the rocker cover off.
Posted: Thu Apr 14, 2011 10:09 am
spratty wrote:can you not work out that no. 1 is on the firing stroke by checking if the rotor arm is pointing at least vaguely to where the HT lead for no. 1 would be? this would save taking the rocker cover off.
Yes.
If the dizzy is out and you don't know which stroke you're on, just take out plug one and turn the engine with a ratchet handle on the crank bolt with your thumb over the hole - you'll feel the compression.
Posted: Thu Apr 14, 2011 2:44 pm
by welshphill
two top tips....
will do it this weekend
thanks guys, as always great advice
Posted: Fri Apr 15, 2011 9:09 am
by bodger
don't use bodger and havn't a clue in the same sentance please ... lol
if you have a look on chris's brillant website , there are a few differant types of dissy and the vac is in a slighty differant place , could be another reason why it won't turn far enough ..just a thought ?
Posted: Fri Apr 15, 2011 10:56 am
The one on the left is Range Rover, the one on the right is SD1.
