Page 2 of 2
Posted: Thu Sep 30, 2010 10:34 pm
by Teesdale_landrover
Got our blos fitted tonight to our 3.9
First impressions are. its allot smoother, picks up without hesitation, with it being a manual you can really tell
Also it seems less restrictive than the mixer we had on and it has more power
Will report back with mpg and after more testing
its easily as good as the lpg injection systems so far, and we have driven them all
Posted: Fri Oct 22, 2010 12:09 am
by bodger
any more conclusions ? and would it work with a flapper setup ?
:D
Posted: Tue Oct 26, 2010 9:01 pm
by Raggylad
I have had a BLOS fitted to my Land Rover (110 V8, running on Strombergs) for about a month now.
Generally pretty happy, though I'm not convinced that I've got it set up correctly yet (no gas tester). Idle is great (was bad on LPG before); low speed responsiveness is excellent; overall mpg is about 2-3 mpg better (quite a lot when you are getting 16mpg at best, 13.5 average); more grunt at motorway speeds with overdrive in. However throttle response under load (accelerating from 40 mph on the level or uphill from 45 to 60) seems less good.
It is a quality bit of kit - I just need to set it up better[/img]
Posted: Sat May 14, 2011 8:30 pm
by mosesthemonk
I too have a gas conversion with a mixer ring before the TB. The intake for the idle control valve on a rover v8 has a hose which draws it's air from between the mixer ring and the TB, thus any air reaching the plenum gets in only from where the lpg enters.
Posted: Thu Feb 23, 2012 10:11 am
by bodger
Hi , anynews on the MPG with the BLOS and general performance ??
i have a FLAPPER system with a mixer ring between the airfilter and airflow meter at the moment :)
thankyou
Posted: Thu Feb 23, 2012 10:51 am
by jan_rrc39v8
only 3% powerloss on LPG
2-3mpg better = over 10% improvement.
Nice!
Posted: Fri Feb 24, 2012 10:44 am
by bodger
:) .... Thankyou
