Page 1 of 3
Twin Plenum Throttle Shafts Help Needed.....
Posted: Mon Dec 04, 2006 8:30 pm
by Coops
Can anyone help me out here
can some one do me a working drawing of the two shafts from a twin plenum please, as i want/need to get some done for the twin plenum,
Allan has the broken ones from the plenum, but i can't get hold of him via e-mail, private message or by phone,
And the ones in the plenum now are modified ones,
Posted: Sat Dec 16, 2006 11:25 pm
by Coops
no body can help then
Posted: Wed Dec 20, 2006 8:54 pm
by topsparks
Try the rover sdi club web site ,they have a tech section and I down loaded the info when I rebuild my TP.
Posted: Sat Dec 23, 2006 5:41 pm
by Coops
you have a link???
Posted: Sat Dec 23, 2006 10:28 pm
by kev_the_mole
Tony,
how long can you wait? I can get the drawing done at work but tolerances might be a bit hit and miss unless the mating parts are available for measurement.
Posted: Sat Dec 23, 2006 10:33 pm
by Coops
Cheers Ian,
i wanted to replace the shafts before racing next year,
BUT need a pair of shafts to measure as mine are modified and from a standard efi, and are a bit worn and have a bit of play in them,
Posted: Sun Dec 24, 2006 7:24 pm
by alex
Hi Tony
I have a twin plenum lying around in the garage I could lend it to you if you promise to let me have it back again unmolested.
Alex.
Posted: Sun Dec 24, 2006 7:30 pm
by Coops
hi alex,
that is most kind of you,
if you want to remove both shafts and measure them up for me it wont have to leave you then mate,
and where abouts are you mate??
Posted: Sun Dec 24, 2006 7:35 pm
by alex
Im in Stoke on Trent.
I will take em out and put em in the post if you want after the holidays.
Then if the measurings wrong it wont be me getting told off
Alex
Posted: Sun Dec 24, 2006 7:43 pm
by Coops
@alex
Reg, how you want to go about measuring these up mate????
as dont want to be sending alex's shafts every where around the country,
Posted: Sun Dec 31, 2006 7:57 pm
by r2d2hp
Hi Tony,
If the can be sent to me I will get them drawn up as my brother inlaw is Senior Draftman for BAE.
And then I will see about getting them made.
Is that ok
Posted: Sun Dec 31, 2006 7:59 pm
by Coops
Alex you ok sending them to Reg????
Posted: Sat Jan 06, 2007 11:58 pm
by alex
Hi Tony
Appologies for the delay in a response.
Yes can send them where ever is easiest pm me an address and will try to sort it out this week for you.
Alex.
Posted: Sun Jan 28, 2007 9:52 pm
by r2d2hp
Received the shaft from Alex (Many thanks). Drawings have been made at reasonable cost and supplied to tool maker and he is asking how many sets we need as if its a reasonable number will make a jig to help production.
Initial ones will be made in brass but could also make in stainless if required at additional cost.
So if you know of anyone who is in need of replacement shafts can you let me know asap.
Posted: Sun Jan 28, 2007 9:55 pm
by Coops
Depending on costs i could be interested in two sets mate,
