Posted: Sun Nov 12, 2017 9:32 pm
I'd modify it for return lines personally! Shouldn't cost much to have a pair of hose barbs added to the dead end and route back to a FPR.
Welcome to the well-known V8 Owners Forum, no matter what you drive if its V8 Powered you'll be made very welcome.
https://www.v8forum.co.uk/forum/
Ok - given that all this is exactly as LR built the system, why would you run return lines from the fuel rails?Random wrote:I'd modify it for return lines personally! Shouldn't cost much to have a pair of hose barbs added to the dead end and route back to a FPR.
Im paranoid about any vapour in the fuel lines. Also temperature alters fuel density.garrycol wrote:Ok - given that all this is exactly as LR built the system, why would you run return lines from the fuel rails?Random wrote:I'd modify it for return lines personally! Shouldn't cost much to have a pair of hose barbs added to the dead end and route back to a FPR.
Garry
And what temperature does your fuel normally run at, vs what temperature it will be here ?Random wrote:Im paranoid about any vapour in the fuel lines. Also temperature alters fuel density.garrycol wrote:Ok - given that all this is exactly as LR built the system, why would you run return lines from the fuel rails?Random wrote:I'd modify it for return lines personally! Shouldn't cost much to have a pair of hose barbs added to the dead end and route back to a FPR.
Garry
Its likely unecessary but its how I always set up my fuel systems!
My SD1 EFI has a factory designed mod to overcome fuel vaporisation on a hot restart. A valve fitted to the fuel return which shuts off, controlled by a thermostat on the rad. And a relay which bypasses the series resistor to the fuel pump. So when cranking, the fuel pressure goes up to the maximum the pump can do.Quagmire wrote:I thought that vaporisation was almost entirely eliminated due to the fact that the pressure in the fuel.rail is what , 3 bar or something?
Same principal as having a pressurised cooling system.
