LT77 (SD1) rear mounting bushes
Posted: Tue Apr 11, 2023 3:34 pm
by marsbar
Apologies if I've missed an answer to this in the forum but......
I'm looking to replace the rear gearbox rubber mounts with polyurethane ones but I can't find any. I can find polyurethane replacements for the gearbox remote bushes and also the bush for the central bolt in the rear mounting bracket but not the main bobbins. Does anyone have any suggestions as to a supplier?
TIA
Chris
Re: LT77 (SD1) rear mounting bushes
Posted: Tue Apr 11, 2023 7:14 pm
by Ian Anderson
Perhaps reach out to someone who used to sponsor the forum
viewtopic.php?f=4&t=2314
Posted: Wed Apr 12, 2023 7:30 am
by marsbar
Thanks Ian, looks like engine mounts only but I will reach out to them and see what they say.
Chris
Posted: Mon Apr 17, 2023 9:02 am
by SuperV8
I'm not sure I see much benefit in polybushes for the gearbox?
from here:
https://www.shop4autoparts.net/parts/ge ... -gbox-sd1/
NOMINAL SIZE mm
Overall Length (Inc Studs) 69.4
Bush Length (Rubber) 35
Bush Diameter 45.6
Stud Length 17
Stud Thread M8
Could try something like:
https://www.polymax.co.uk/anti-vibratio ... bin-mount/
Put in what size you need and the have a selection of materials. Have not used them before.
example:
Article No. D (mm) H (mm) G x L (mm) Max Load Comp (kg) Max Shear Load (kg)
A5035M823-2 50 35 M8 x 23 154.80 53.00
You can DIY poly bushes - get some 2 part polyurethane, you can get it in different shore grades - make a simple tube mould, providing your threads and plates are serviceable?
