Flywheel, Rear Crankshaft Seal & Bearing
Posted: Tue Aug 30, 2016 12:50 pm
I've completed the tear down of my driveline and I need some advice on a couple of things.
1) condition of the flywheel, all the way round the mating surface there are cracks in the surface, is this usual? Can this be skimmed?
2) Can someone point me to a removal proceedure for the rear crank seal and the phosphorus Bronze shaft bearing / bushing. 3.5 RV8 SD1
3) What size 'normal' input shaft? This is currently using the 20.4mm shaft of the 924 but I am thinking to upgrade to the 25mm shaft of the 944 driveline.
The seal actually looks ok but might as well change it now I'm hear, the bronze type bushing looks some what beaten up.
https://www.flickr.com/photos/144556909 ... res/mKmEaq
Bear with me, this is the first time I have attempted such an overhaul on anything.
